Best Android tablet 2024
Samsung's Tab S9 series leads the pack.
The best Android tablets range from basic couch companions to feature-packed behemoths that could sit next to some of the most powerful laptops on the market. The key to finding a dream device comes down to finding the tablet that works best for you and your needs.
For most folks, the best tablet on the market might just be the new Galaxy Tab S9 from Samsung, but the entire S9 lineup is a triumph, offering exceptional performance delivered by a Snapdragon chip, beautiful displays, and enough durability to handle all of life's ups and downs.
The main drawback is that this premium experience comes at a premium price, so if you're trying to save money, check out our guide to the best cheap Android tablets.
In between figuring out ways to put retro emulators on everything, Andrew thoroughly enjoys exploring what's possible with Android tablets. He's constantly looking for new and different ways to use tablets, such as replacing his laptop or turning tablets into smart home dashboards.
At a glance
Best overall
Best overall
The Galaxy Tab S9 rests firmly in the Goldilocks zone between premium specs and value, with a great Snapdragon processor, lovely display, and upgraded S Pen.
Best alternative
Best alternative
It might not look like it, but the OnePlus Pad 2 is quite the upgrade over the original. It's the first Android tablet powered by the Snapdragon 8 Gen 3, packing an impressive punch without breaking the bank.
Best for Pixel fans
Best for Pixel fans
The long-awaited Pixel Tablet is an excellent choice if you enjoy the Pixel experience, offering a sophisticated design, free Charging Speaker Dock, and the Tensor G2 chip.
Best premium tablet
Best premium tablet
If you can afford it, the S9 Ultra is one of the best tablets around, complete with a huge 120Hz display and a Qualcomm Snapdragon 8 Gen 2 chip.
Best cheap tablet
Best cheap tablet
The Galaxy Tab A9+ might not be earth-shattering in the specs department, but you still get an ultra-thin device with a metal construction, great battery life, and an even better price.
Best for students
Best tablet for students
Boasting a compact, ultra-portable design, low price point, and up to 14 hours of battery life, the Amazon Fire Max 11 fits perfectly alongside the hectic student lifestyle.
Best overall
1. Samsung Galaxy Tab S9
Our expert review:
Specifications
Reasons to buy
Reasons to avoid
The Samsung Galaxy Tab S9 spec sheet leaves little to be desired, with the cutting-edge Snapdragon 8 Gen 2 processor, 8GB of RAM, a microSD slot for expandable storage, and durable battery life. Since it's a Samsung product, you're getting a best-in-class display — coming in at 11 inches with an ultra-smooth 120Hz refresh rate — and a scratch-resistant aluminum build.
You also get extras like excellent quad speakers, an in-display fingerprint sensor, and an S Pen stylus included in the box. Plus, you can attach a keyboard cover to get some work done and then jump into the DeX desktop-style interface for a more laptop-like experience.
Most importantly, Samsung’s One UI software makes multitasking on the Tab S9 remarkably easy. You simply drag your favorite apps from the pinned taskbar onto the display, and the UI automatically splits them into resizable windows or squeezes them into compact pop-up windows.
Still, with a starting price of around $799, the Tab S9 isn't exactly cheap, but it's considerably more affordable than the other tablets in the lineup, the S9 Plus and S9 Ultra. And like all of the best Samsung devices out there, the S9 will receive four years of major Android updates along with five years of security updates.
Best alternative
2. OnePlus Pad 2
Our expert review:
Specifications
Reasons to buy
Reasons to avoid
It was clear after the original OnePlus Pad was released that the company still had work to do if it wanted to compete in the tablet market. What's also clear is that OnePlus listened to some of the feedback before launching the OnePlus Pad 2 in July 2024.
Although the design aesthetic largely remains the same, the Pad 2 introduces a larger 12.1-inch 3K display, up from the 11.6-inch screen in the previous model. It came as a surprise to see that OnePlus was opting against using an OLED panel, as the Pad 2 relies on an LCD display. However, between the 3K resolution and 144Hz refresh rate, it's just about enough to make you forget what type of panel is being used.
As for power, the OnePlus Pad 2 is the first Android tablet powered by Qualcomm's Snapdragon 8 Gen 3. This is paired with 12GB of RAM and 256GB of storage, giving you plenty of power for games or taking advantage of the Open Canvas multi-tasking. The only downside here is that you won't find a microSD card slot, which is a disappointing omission.
Unlike others on this list, OnePlus sells both a detachable keyboard cover and a stylus for the Pad 2. However, neither of those is included in the box, so you'll be spending even more for the complete ensemble. Even still, you can get all three and it will cost the same as the 12GB/256GB Galaxy Tab S9 model, which includes the S Pen, but no keyboard.
Best for Pixel fans
Specifications
Reasons to buy
Reasons to avoid
To call the Google Pixel Tablet highly anticipated would be an understatement. We’d been waiting for Google to get back into the tablet game for years, and although it’s far from a dramatic return, the Pixel Tablet certainly doesn’t disappoint. It should basically be a perfect tablet for most people (unless you're a gamer), complete with a vibrant display, some excellent battery life, and all the Google software support you could ever ask for.
It even comes with a Charging Speaker Dock, a useful little stand that converts your tablet into a smart display. If you didn't want the Dock, you're in luck. Just before I/O 2024, Google relaunched the Pixel Tablet, sans the Dock, which dropped the price down to $399.
Now, there are a few quirks with the Pixel Tablet. The bezels, for one, are strangely large, and there’s no 3.5mm audio port to help make up for the weak speaker quality. All in all, though, we found the tablet to be sufficiently powerful for most tasks, and if you’re a Pixel fan, there’s really no reason to skip this device. Holding it in your hands almost feels like you’re using an oversized Google Pixel 9, and that’s a good thing.
Best premium tablet
Specifications
Reasons to buy
Reasons to avoid
At 14.6 inches and 1.6 pounds, the Tab S9 Ultra belongs on your desk. Combined with the impressive 90% screen-to-body ratio, the display size makes it the champion for fitting multiple full-sized apps at once; and you can buy a backlit keyboard cover with a trackpad, converting it into a modular laptop.
The downside of its design is that the Tab S9 Ultra’s tiny bezels leave you no room to hold it without accidental touches, while also exposing a notch that you’ll have to learn to ignore. You essentially have to use it docked, and the official keyboard cover ships separately and costs a healthy amount. Combined with the RAM upgrade, a fully-specced and accessorized Ultra will cost you about the same as a premium laptop.
If that’s a problem, you could settle for the also-great Tab S9 (described above). But if you can afford it, or you simply want the most powerful Android tablet on the market regardless of price, you’re getting excellent performance and a massive slab for gaming, streaming, and working with the S9 Ultra. You merely have to accept that it’s not at all portable. As stated in our Galaxy Tab S9 Ultra review, this is the ultimate tablet and laptop replacement, but its size might prevent it from becoming the ultimate couch companion.
Best cheap tablet
5. Samsung Galaxy Tab A9+
Our expert review:
Specifications
Reasons to buy
Reasons to avoid
If you're looking to buy a tablet for the first time and don't have any stringent needs, the Galaxy Tab A series is an excellent option for a fraction of the Tab S9's cost. While you won't be blown away by its specs or features, the Tab A still manages to offer a metal body. And unlike Amazon's Fire Tablets, it has a fully functional version of Android with Google services like the Play Store, so you can download any apps you want.
The Galaxy Tab A9+ is a great option for those in the market looking for an entry-level tablet that offers a traditional Android experience. Although it shares the same 11-inch screen size as the Galaxy Tab S9, the Tab A9+ won't weigh you down as it's perfect for sitting back and watching a movie on the couch, or using it to catch up on reading.
One area that may cause some disappointment is the lack of S Pen support. This is one of the defining features of Samsung's other devices and was once the case with previous iterations. Unfortunately, it seems that Samsung has shifted its focus to making an affordable "around the house" tablet, as opposed to one meant for productivity and multitasking.
Specifications
Reasons to buy
Reasons to avoid
There's a good chance that when you think about Amazon tablets, you think about the Fire 7 which can usually be had for less than $50 on Black Friday. In 2023, Amazon proved that it's trying to offer more than just super-cheap tablets, as evidenced by the Fire Max 11.
Ditching the build with chonky bezels, the Fire Max 11 is sleek and well-built, turning in plastic for aluminum. While the company hasn't made the jump to OLED panels just yet, this 11-inch IPS screen is quite impressive. Not to mention that it's great for movies, getting work done, or acting as a smart display.
Amazon also offers a detachable keyboard and USI pen for the Fire Max 11. These, paired with the 14 hours of battery life, ensure that you'll be able to take notes and finish assignments with ease. The Fire Max 11 Productivity Bundle even includes three months of Microsoft 365 if you need an easy way to share files or access Microsoft's suite of productivity apps.
The big caveat to keep in mind with an Amazon Fire Tablet is that you don't get the Google Play Store or Google's great apps and services. Instead, you'll rely on the Amazon App Store, which has a dramatically more limited app selection. But for this price, that's an OK trade-off for most people, especially for students on a budget.
Compare specs
Header Cell - Column 0 | Samsung Galaxy Tab S9 | OnePlus Pad 2 | Google Pixel Tablet | Samsung Galaxy Tab S9 Ultra | Samsung Galaxy Tab A9+ | Amazon Fire Max 11 |
Display | 11-inch OLED, 2560 x 1600 | 12.1-inch LCD, 3000 x 2120 | 10.95-inch LCD, 2560x1600 | 14.6-inch OLED, 2960 x 1848 | 11-inch LCD, 1920 x 1200 | 11-inch LCD, 2000 x 1200 |
Processor | Qualcomm Snapdragon 8 Gen 2 | Qualcomm Snapdragon 8 Gen 3 | Google Tensor G2 | Qualcomm Snapdragon 8 Gen 2 | Qualcomm Snapdragon 695 | MediaTek MTK8188J |
Memory | 8GB RAM, 128 / 256GB storage | 12GB / 256GB | 8GB RAM, 128GB / 256GB storage | 12GB / 16GB RAM; 256GB, 512GB, or 1TB storage | 4GB - 8GB RAM / 16GB, 128GB, 256GB storage | 4GB RAM; 64GB / 128GB |
Cameras | 13MP AF, 12MP UW front | 8MP front, 13MP rear | 8MP front, 8MP rear | 13MP AF + 8MP UW + Flash; 12MP (wide) + 12MP UW front | 8MP rear, 5MP front | 8MP rear, 8MP front |
Battery | 8,400mAh | 9,510mAh | 7,020mAh | 11,200mAh | 7,040mAh | 7,500mAh |
Dimensions | 165.8 x 254.3 x 5.9mm | 268.66 x 195.06 x 6.49mm | 258 x 169 x 8.1mm | 326.4 x 208.6 x 5.5mm | 257.1 x 168.7 x 6.9mm | 259.1 x 163.7 x 7.5mm |
Weight | 1.1lb | 1.28lb | 1.08lb | 1.61lb | 1.06lb | 1.08lb |
Price | $799 | $549 | $399 | $1,199 | $219 | $229 |
Honorable mentions
It can be rather overwhelming trying to decide which is the best Android tablet, simply because there are so many options. This is also why we've expanded the list a bit to include a few honorable mentions that didn't quite make the cut, but should definitely be considered.
Best E Ink Android Tablet
It might seem odd to consider an E Ink tablet, but the Onyx Boox Tab Ultra C Pro might change your mind. It's running Android 12 out of the box, meaning that you aren't limited to just one ecosystem for reading or taking notes. Although you might not want to use this for watching movies, there's really not much that the Tab Ultra C Pro can't do.
Best Android tablet for kids
While this wasn't always the case, there's a growing focus on offering great Android tablets for kids. The Fire HD 10 from Amazon should come as no surprise as being our top pick. Its versatility can't be understated, as it's great for either media consumption, or helping your little ones learn. Plus, with the included case, giving you a bit more piece of mind.
Best for gaming
The Razer Edge might seem like an odd choice for this list, but in reality, it's just an Android gaming tablet with a detachable controller. This means that you can remove the Kishi V2 Pro and use it just as you would any other Android tablet. Plus, there's a cellular version available for those who want to be able to game on the go or just use a tablet away from home.
How to choose
There are a lot of factors that go into deciding whether the best Android tablet is right for you. Price is likely the most important factor, but that also ties into the value of a tablet. For example, just because the Galaxy Tab S9 Ultra is the most expensive Android tablet doesn't necessarily mean that it's the absolute best. There are plenty of great tablets that will work for your needs but won't break the bank.
Size is another important factor, but this also depends on what it is that you're trying to accomplish by purchasing a new tablet. If you just want a lightweight media consumption device that's not your laptop, then devices larger than 10 inches might not be right for you. But if you are planning to get some work done away from your desk or the office, then a tablet with a larger screen will be the better fit.
With those two factors taken into consideration, you'll want to look at other features such as battery life, screen resolution, camera quality, and design. There's also the question of the "intangibles." Does the tablet include a stylus? Is there a detachable keyboard available? Is that included? What about cases? Are case options limited to first-party options, or are there a bunch of third-party solutions to pick from? These are all questions we consider when performing our reviews, along with determining which Android tablet is "the best."
How we test
☑️ One of the oldest and most trusted Android sites on the web
☑️ Over 15 years of product testing
☑️ Thousands of products reviewed and tested since 2007
☑️ Over 50 phones and tablets tested every year by our team
Along with the questions and factors that we outlined above, when it comes to reviewing and testing these devices, we try to take into account every other possible detail. For example, we look at the build quality and durability of different tablets that come across our desks, short of doing actual bend tests.
Because we'll be looking at these screens for long periods of time, we want to know the same things as you, including if you can actually see the tablet under direct sunlight. How does the latest Netflix hit look, and what about HDR or Dolby Atmos compatibility? Speakers are another big thing with tablets since you shouldn't always have to reach for a pair of headphones if you're watching a movie.
And circling back, there are the aforementioned "intangibles" to consider, such as determining whether you can actually use a tablet as a laptop replacement of sorts, depending on the model. Plus, there's the whole question of battery life, as you don't want to end up with a tablet that can't even make it through the latest Marvel movie without needing some juice. All of these factors play an important role in making our final determination and providing a score for the review.
FAQ
Which of the best Android tablets should you buy?
Picking a quality Android tablet typically boils down to either Samsung or Amazon models. Samsung dominates the premium and mid-range tablet market while competing with Amazon via its cheaper, budget A-models. So when weighing the best Android tablet for you, specifically, start with Samsung unless you don't have much money to spend.
In terms of the “best” without regard to money, it’s a toss-up between the three Tab S9 models. The 11-inch Galaxy Tab S9 is the best mainstream pick, coming in lighter, brighter, and more affordable than its larger siblings while sporting the same flagship Snapdragon chip. It even has the longest battery life of the bunch at about 15 hours.
Then again, you might want to consider the Galaxy Tab S9+ instead. You’ll trade in the S8’s basic LCD panel for a 12.4-inch AMOLED, giving you richer colors, deeper blacks, and more screen space for fitting in multiple apps at once. It also has a shorter S Pen latency at just 2.8ms, so short that you’ll feel like you’re writing on actual paper. Though more expensive and less comfortable to hold, the Tab S9+ display justifies the upgrade.
The Galaxy Tab S9 Ultra measures a massive 14.6 inches and 1.6 pounds with tiny bezels, making it wholly unsuitable for casual streaming in bed, but perfect as a laptop replacement using Samsung DeX mode. It’s the Android equivalent of the iPad Pro, with the price and power to match. If you want an Android tablet with more than 8GB of RAM, this is your best (and only) choice.
Dropping into the mid-range category, the Galaxy Tab S9 FE provides the same display size and battery as the S9+ for about half the price, if you can stomach some performance downgrades.
But for true affordability and value, you’ll want to look at Amazon’s catalog, starting with Amazon's Fire Max 11. The specs are nothing to write home about, but performance is surprisingly good, and you get a great media consumption device for a highly competitive price. The only catch? The Fire Max 11 runs Amazon's Fire OS rather than a more typical Android build, meaning you'll need to download apps from Amazon's app store rather than Google's.
Is getting a tablet worth it?
This is a question only you can really answer, but a better question might be "what do I want or need a tablet for?" If you're looking to replace an aging laptop with a tablet, there aren't as many options available, and instead, you might be better suited with a great Chromebook.
Determining what it is that you're planning on using the tablet for is the first step of the equation. Because if you don't have an actual use case for the device, then it'll likely end up just gathering dust.
But the great thing about tablets, regardless of the price, is that they can solve a lot of different problems and come in a bunch of different software flavors. If you're entrenched in the Amazon Alexa ecosystem, then a Fire tablet might be better suited for your needs. Then there's Google's Pixel tablet which arrived in 2023 offering users something different with the included dock. And if you're a fan of the "stock" Android experience, this might be the perfect tablet for you.
What is the difference between Cellular and Wi-Fi tablets
Most of the time, there are no major differences when purchasing a tablet with cellular service compared to a Wi-Fi version. In some instances, there might be a slight weight difference, along with the addition of a SIM card slot, but the overall design and functionality will remain the same.
Instead, the difference between these tablets comes down to whether you want to have an "always-connected" device, or if you're fine relying on Wi-Fi connections. The former allows you to have a constant internet connection but comes at the cost of an additional line of data (read: higher monthly bill). Cellular tablets also have a tendency to suffer a bit in the battery life department since they're always trying to find a suitable network connection.
As for Wi-Fi tablets, you might not think that there's much of a cost to consider, but something to keep in mind is when you want to use the tablet and aren't within range of a Wi-Fi network. In that case, you'll need to use your phone's built-in portable hotspot, but that's not a feature immediately available on every cell phone plan. Going this route will also result in your phone's battery draining much quicker than normal, along with potentially eating up your mobile data allotment.
Be an expert in 5 minutes
Andrew Myrick is a Senior Editor at Android Central. He enjoys everything to do with technology, including tablets, smartphones, and everything in between. Perhaps his favorite past-time is collecting different headphones, even if they all end up in the same drawer.
- Patrick FarmereCommerce Editor
- Michael L HicksSenior Editor, Wearables & AR/VR
Joshua Luther1 How is the regular Tab S8 not on this list? It is just as good as the Plus and Ultra, just smaller. And it's far better than the Pixel Tablet.Reply -
lata chaudhary My first choice is Samsung Galaxy Tab S8 Ultra.Specifications: Display: 14.6 inches, 2960x1848 (240 ppi)Reply
Processor: Snapdragon 8 Gen 1
Memory: 8GB / 12GB / 16GB RAM, 128 / 256 / 512GB storage
Cameras: 13MP AF + 6MP UW, 12MP FF + 12MP UW
Battery: 11,200mAh
Dimensions: 12.85" x 8.21" x 0.22", 1.60 lb
Colors: Graphite -
pat008 why is there no mention that pwm is used on these (am)oled screens so s8+,s8 ultra, lenovo ...Reply -
fuzzylumpkin
There's only one person at AC who cares about PWM stuff.pat008 said:why is there no mention that pwm is used on these (am)led screens so s8+,s8 ultra, lenovo ...
It's like wondering why no one ever mentions accessibility features in general in reviews... unless it directly affects them, people generally don't give a shit. . -
dharr18 How is the OnePlus Tab not even mentioned? 144 Hz refresh and excellent battery life. Truly is a great tablet with great performance at a reasonable price. Also has first-party add-ons like Stylo and keyboard case. Usually I have a tablet as a media device, but I find myself using the Tab more than my Chromebook or my phone.Reply
I have a problem with the great bloat loaded on every Samsung device I ever owned.
Having an Amazon tablet listed when you are restricted to their App store unless you hack it makes the omission of other tab options even more surprising.
I even think it is funnier that there is no link for the Lenovo to purchase. That tablet is a monster in size.
